Double Roller balancer
I’m putting back together a 22R with a double roller timing chain kit. Should the harmonic balancer be flush where crankshaft bolt holds it on? Trying to figure out if the wrong oil pump gear is on there or if the balancer just doesn’t go on all the way with double roller kit. I noticed oil pump is a little different.
| All times are GMT -8. The time now is 02:21 AM. |
