Distributor, timing
I had been having idle issues, which I think are solved now by properly adjusting the TPS. When I was having idle problems, I loosened the nut that holds the distributor in place, and moved it. I would like to make sure I have it back in the right place. How can I do that? Thanks, Josh
Need to know which motor you have.
You would need to jumper two ports in your diagnostic box (forget which ones) and then check timing with a timing light and adjusting distributor accordingly. Or just move it until it appears to be running smoothly and well.
Originally Posted by LITLRED
(Post 52012567)
Originally Posted by vermontoyota
(Post 52012576)
You short terminals te1 and e1 and you need a timing light to accurately set timing. If you don't have one check with your local auto parts store they probably rent one out.
Ok, thank you very much. Where are the terminals located?
Do you know the timing specs? I'm thinking it should be a -5 BTDC or somewhere around there. Thanks |
On my '88 there is a fuse block in behind the battery (closer to the cab). The te1 and e1 are located in a little covered thingy just in behind the fuse block. Stick a paper clip in te1 and the other end in e1. Grab your timing light and point at the timing mark just above the crankshaft pulley. Look for the notch in the pulley - as you twist the distributor, you should see it move in relation to the timing marks. For the 22RE, set timing to -5 and you are good to go.
Codes... http://4crawler.com/4x4/CheapTricks/...es/index.shtml
Video for installing distributor>>>> http://www.youtube.com/watch?v=9qEQM...ature=youtu.be How to get Check Engine Codes and to set Timing. I just put this up for others. Applies to 87 and up. 86 and older is the bottom picture. http://i1098.photobucket.com/albums/...rys87/T1E1.jpg The Diagnostic port for the 85-86 is on the Drivers side inner fender and is nothing the same as the 87 and up. Here is T1 and E1 jumped. The codes and engine flashes are the same as the rest of the trucks on the dash. http://i1098.photobucket.com/albums/...s87/86diag.jpg Codes...http://4crawler.com/4x4/CheapTricks/...es/index.shtml Video for installing distributor>>>> http://www.youtube.com/watch?v=9qEQM...ature=youtu.be |
Wonderful, thank you! This has been a big help.
