YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Differential compatability (https://www.yotatech.com/forums/f116/differential-compatability-109957/)
mtrdrms Mar 12, 2007 12:50 PM
I have an 89 4runner V6 5speed and I want to regear it to 4.56 or 4.88. To save myself the hastle of regearing my own, I am looking for a used set from a similar model. My questions are:
1. Are trucks and 4runner diffs the same?
2. Salvage yards keep asking me if its a 4 or 6 cyl, reg cab or extended. Does this matter?
3. What year trucks and/or 4runners are direct bolt in applications?
4. Are there any other considerations that I should know about before I drop 500 bucks on a set (ADD, auto hubs, etc.)?
Thanks from the eternal noob,
Andy
mt_goat Mar 12, 2007 01:19 PM
Andy
(For the rear diff)
1. For an 89 they should be, some models of pickups will have a rear anti-lock brake sensor hole and some don't.
2. There are different diffs for the 4 and 6 cyl models, the V6 3rd is a little stronger but you can use a 4 cyl 3rd in a V6 axle housing (I did for about 45,000 miles)
(I don't know about the front)
Yota82 Mar 12, 2007 01:33 PM
The only real difference if between the V6 and 4 cyl rearend. The V6 3rd's have larger bearings and stronger carriers. They are pretty much all interchangeable.
mtrdrms Mar 12, 2007 02:08 PM
86-95? Sweet. That makes the search so much easier. So if a front has an ADD and I put it in my older 4runner, I can run it without it making a difference?
tc Mar 12, 2007 02:15 PM
The rear you can go up to at least 2000 in a 4Runner. The elocker can be made to work too (but they only came with 4.10 and 4.30).
As for the front, I'm not sure about using an ADD diff on a non-ADD truck. I know you can do the other way around - it's a pretty common mod for people who have issues with the vacuum actuation system. Search on ADD removal or conversion.
westy44runner Mar 12, 2007 02:34 PM
If you want 4.88 diffs, some of the 90-95 4runners came with this from the factory. Look for a 90-95 4runner with the 3.0, auto tranny and 31" tires from the factory, these will have 4.88s. Check the drivers door sticker.
tc Mar 12, 2007 02:35 PM
Note that the factory 4.88's are not regearable. If you DO go this route and change your mind, you're back hunting for diffs again.
mt_goat Mar 12, 2007 03:02 PM
Pickups too (with the 3.0, auto tranny and 31" tires from the factory) had 4.88s. But yeah make sure you really want 4.88s.
mtrdrms Mar 12, 2007 03:48 PM
What makes them not interchangeable?
tc Mar 12, 2007 04:27 PM
The pinion is offset in the housing so the ring gear is a totally different thickness. I wouldn't say it's a RARE option, but there surely aren't enough out there to interest the aftermarket in tooling up for replacement gears with the special thickness.
