Old 03-30-2016, 03:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Steering & Suspension Guides
Print Wikipost
Diagnosis: Replace Rear Differential Bearings!
Old 02-07-2008, 07:31 PM
DJK-West's Avatar
Been thinking....
Perhaps going for a used third member would be a better option for right now. Now the question is, what's a good place to get them aside from the wrecking yard? And what should I look for when determining if the third member has signs of bad wear and tear? Also, I know the third member on our V6 4Runner has 8" ring gear. Would the third member from other Toyota trucks fit as long as it has the same size ring gear?
Old 02-08-2008, 11:38 AM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
Originally Posted by Yodaforce
...Humming and sometimes vibration from the rear could be from abnormal ring and pinion wear (or bean burritos)...
No one caught this gem of comedy?
bahahahaha
that was tooo much!
Old 03-20-2008, 06:12 AM
dean s's Avatar
Thumbs down jobber rear seals
had my rear seal done in montana on my way home from picking up this pile of trouble and the shop was also a Napa dist. and the mach.wouldn't use their seals because the seals were just made of off shore beer cans!!! real thin he showed me the difference!like night and day
Old 07-11-2008, 03:14 PM
what did you end up doing? my diff is about to take a crap now I think...
06-01-2021 01:51 PM
voiddweller
19
05-02-2016 09:10 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Diagnosis: Replace Rear Differential Bearings!
