YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Dash Pot? (https://www.yotatech.com/forums/f116/dash-pot-270288/)
easterly81 Jun 25, 2013 09:42 AM
What does the DashPot do?
What exactly does the dashpot due and is it important?
Discombobulated Jun 25, 2013 10:21 AM
Well since you didn't ask for what on what why or anything else here is a link to Wikipedia:)
https://en.wikipedia.org/wiki/Dashpot
scope103 Jun 25, 2013 04:38 PM
The injectors spray liquid gasoline, but the engine uses only gasoline vapor. A small amount of the sprayed gasoline clings to the inside of the intake manifold, but at steady state (driving down the road), that gasoline is evaporating as fast as it is getting replaced.
To go from idle to steadily running, it has to build up that thin layer of liquid gas. On a carbureted engine, you have an "accelerator pump." On a fuel injected engine, the injectors stay open a hair longer when the throttle opens.
But what happens when you slam the throttle closed? Not much air, but a bunch of liquid gas evaporating into the intake stream. So the mixture goes very rich, back fires through the exhaust, and ruins the air we breath. So all engines (carbureted or injected) have something to keep the throttle from slamming shut.
If you lose the dashpot, whenever you jump off the throttle you'll dump a bunch of unburned fuel into the exhaust, which isn't good for anything. You can get around it by always closing the throttle gently, but why worry about that when a little gadget will do it for you?
Yes, it's important. Now you know why.
Gevo Oct 4, 2013 07:33 AM
I appreciate this explanation for what the dashpot on the throttle body does... Interesting... during this rebuild I was looking at it... I won't replace mine, but I won't remove it either.. :)
Robert m Oct 4, 2013 01:02 PM
so what happens if you dont have one? mine has been missing since i had a new engine put in about 60k ago.
Gevo Oct 4, 2013 01:17 PM
Did you read this?
RSR Oct 4, 2013 11:32 PM
Originally Posted by Gevo (Post 52124922)
Did you read this?
:good:
Over the long term you risk burning up your cat and/or over immediate term backfiring if cat's already removed/element collapsed into powder/pieces...
Robert m Oct 6, 2013 12:47 PM
Did you read this?
sure as hell didnt
