YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Dash board replacement.HELP (https://www.yotatech.com/forums/f116/dash-board-replacement-help-287720/)
barrentine Mar 22, 2015 09:27 AM
I have a 1989 Toyota 4x4 deluxe pickup.Will a 94 dash board fit this truck?Also I have a tilt steering to go in also.The only problem I see with it is that the tilt steering doesn't have the universal joint type connector.It just has splined shaft.Is there a universal available for this.thanks
thefishguy77 Mar 22, 2015 09:48 AM
I believe the dashes should swap with relative ease. There may be some small differences due to factory options but the trucks are the same size. As far as steer goes. I have absolutely no friggen idea. Good luck hope this helps
