Crappy mpg after new coil pack and tune up.
'99 4Runner, 3.4, 5spd, 156K miles. I had the coil pack on cylinder 3 go bad. Replaced coil, wires and plugs. Also changed fuel filter while I was at it. Mileage before coil started failing was averaging 17-19mpg. Mileage dropped to 14-15 when truck was running poorly. Just filled up after a week with the new parts in, and I still only got 14mpg. I cleared the code after the new parts went in and the truck is running great, just crap mileage. Any ideas?
Thanks, Hodag
Thanks, Hodag
you'd get more answers in the right section. i would double check all the plugs are pluged in to the correct location. also maybe switch the coil pack around to see if it changes the CEL code. i was also getting a misfire cylinder 3. toyota had replaced the plugs 2 years ago. needless to say my plug was wicked loose, and it solved my misfire.
the1998sr5
15
07-14-2020 08:35 PM
priest16
15
08-06-2015 07:43 AM
