Cooling System Issues - Steam but guage reads ok.
I had to run an errand about 10min from work at lunch time today. My truck (86 4runner with a 22re) seemed to be running great and all the gauges looked normal, but after sitting in the parking lot for 5 minutes I come back out and there's steam coming out of the hood that smells strongly of coolant.
I put the key in the on position and the temp gauge reads about a quarter of the way up, which is it's usual warm position. Since I was parked in a lot when I should not have beenI and did not want to get towed, I decided to risk the half mile drive to my house. By the time I got home, no steam, or any visible leaks/puddles. Does anyone have any ideas other than testing my thermostat and temp sender and trying to recreate it in the driveway? We're planning a 300 mile trip up into the mountains this weekend on the runner and I'd like to be confident in it. Thanks for the help. |
broken or cracked hose/fitting/radiator. did you check the coolant level? |
The 1/2 mile drive might not have heated the engine enough to open the thermostat, and your leak may be on the downstream side. Sit it in the driveway and idle it enough to heat it up. Look for steam or any visible water/coolant.
Wear safety glasses and carry an old towel to throw on anything really spraying. 190° water can really hurt you, so be careful. |
Ten minute drive, five minutes sitting with the engine off, visible steam coming out of the engine compartment..
You should have popped the hood and found the source. It was an emergency they can't just tow you off. The guage should have read higher than its normal cruise temp due to heat soak. You probably should not trust it (the guage) with out verification the fluid levels are correct, the voltages are correct, and there isn't air in the system. Coolant tends to leave a distinct discoloration, look for it. Plan accordingly, change plans.. |
Fixed, I hope.
It looks like someone put a coolant flush fitting in the upper heater hose that was leaking on to the exhaust manifold, so it it was a 5min fix.
Originally Posted by Red86Runner
(Post 52415514)
Yeah, that plastic Tee is not reliable. My truck came with it so I want to replace that hose with a straight one, then reserve existing hose with Tee only when needed for flushing. |
(Post 52415517)
Good u caught it.
Yeah, that plastic Tee is not reliable. My truck came with it so I want to replace that hose with a straight one, then reserve existing hose with Tee only when needed for flushing. worth noting they do say on the package not.to leave the flush tee on it for regular duty, it's just meant to be in place while flushing.. |
Originally Posted by Co_94_PU
(Post 52415518)
...worth noting they do say on the package not.to leave the flush tee on it for regular duty, it's just meant to be in place while flushing..
