YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   continuisly leaking oil (https://www.yotatech.com/forums/f116/continuisly-leaking-oil-201244/)
demolishionc4 Jan 12, 2010 05:20 AM
ok so far ive replaced the oil pump gasket, the front main seal, and installed a sleeve on the harmonic balancer and im still leaking oil out the main seal. does anyone have any ideas on why? o its a1989 pickup with a 22re
thedanned Jan 12, 2010 09:25 AM
PCV plugged?
weaselman Jan 12, 2010 11:43 AM
I kno you have tried a sleeve.
But get the 'updated' oil seal from toyota.
I did, spent the 13 dollars and it hasnt leaked in over 6000 miles...
Had same problems as you..
I will try to find the part number when i get home
(at work now)
