Combination Turn Signal and Parking Lights...w/ Budbuilt Pics!
Okay, so I have been doing a little bit of work on the '86. I've installed a Sonoran Steel IFS brace, some 31" MTs, and some low-pro bumpstops. I also removed the behemoth of a front bumper I had, and realized that I had no place to mount my turn signals. So, I wire tied them to my grill, and went on my merry way. However, I grew tired of the Whiskey Tango look, and decided to turn my Parking Lights in to combination Parking/turn Signals.
Here you can see my wonderful grill: http://img.photobucket.com/albums/v1...2-13-07009.jpg This what the Parking Light looks like with the stock connector in place: http://img.photobucket.com/albums/v1...2-13-07014.jpg http://img.photobucket.com/albums/v1...2-13-07015.jpg I removed the connector, and dremeled out the mounting tab, shown here: http://img.photobucket.com/albums/v1...2-13-07016.jpg I then found a socket for a 1157 bulb: http://img.photobucket.com/albums/v1...2-13-07017.jpg The parking light has a green and a white wire to it, and the turn signal does as well. The green is power, and the white is ground. To connect everything up, I used the two white to create a common ground, and attached it to the socket with the spade tab. The 25W filament of the 1157 is used for the turn, and the 7W is used for the parking light. I determined which was which by trial and error, as the socket does not label the respective wires. Here you can see one side done, and other in progress: http://img.photobucket.com/albums/v1...13-07018-1.jpg And the finished product: http://img.photobucket.com/albums/v1...2-13-07019.jpg In addition to the other stuff, I installed a BudBuilt single case crossmember and skid. These things are freakin BEEFY! Installation was straight forward. Support the tranny/case, remove old stuff, install new stuff. You will need a new low-profile drain plug for your case, and a 10mm allen to tighten it down. 12" isnt much, especially with the 90* angle this thing has: http://img.photobucket.com/albums/v1...2-13-07007.jpg A nice side shot: http://img.photobucket.com/albums/v1...2-13-07008.jpg http://img.photobucket.com/albums/v1...2-13-07010.jpg And an up close and personal shot: http://img.photobucket.com/albums/v1...2-13-07013.jpg I gained a full 2.5" in some areas of the skid, and no less than 2" all around. So, from 27" tires and a stock crossmember, to 31s and a BB, I have gained 4" of clearance, and with the SS brace, a nice new skid mount as well.. Fergie |
Nice work on the signals, they look good. I think I may have to get one of those crossmembers. I always get hung on mine.
Nice write up there
*adds to favorites yea, someday ill buy a new crossmember but I want to do dual T-cases and am not sure if a dual will cause interference if i only have one t-case right now :/ i dont want to buy a single now and a double when i do duals... |
I dont see myself going to duals any time in the near future, so this was a good investment for me, especially since I got hung up on the stock one several times last wheeling trip.
kinda looks like the back end of the plate hangs down a lot... shouldn't it be "flat" (parallel to the frame)...?
looks better now that there not held on with zip ties and rope
Originally Posted by CanTheWhales
(Post 50431405)
Fergie |
Yeah, they slope down with the way the t-case fits. I love mine. Lookin' good Fergie! What's your plans for the front bumper?
Well, I've got some 3/16" plate in the garage that I'll cut up to reinforce and brace the front crossmember, and then....I have no idea.
The bumper will have an integrated winch mount, although it wont receive the winch right away. Something lo-pro, most likely out of square, don't like the round tube stuff much for a front bumper. |
Originally Posted by amgraham
(Post 50431468)
(Post 50431840)
got any pictures of your's...? I've never seen that before and would like to see another one...
http://www.amgraham.com/photogallery...53-800X600.JPG But, I did take care of that downslope after a hard wheeling trip though :hillbill: : http://www.amgraham.com/photogallery...89-800X600.JPG There on tons more pics on my site (link is in the sig). |
