code 52
im getting a code 52 on my 3.0. I just swapped out blown engine for a good 3.0. I put a new timing belt on it before the install. I had to change out wire harness as well. The old harness knock sensor had a single black wire shielded with outer wire mesh looking wire kind of like a coax cable. The new harness has two seperate wires a brown and a black. I was told to hook the black to black and brown to mesh.I did that put all together and start it runs good at idle but give it gas and i get a code 52. I was carefull on putting on timing belt to keep in time if but if moved would that cause a code 52? dont know where to start look at timing or knock sensor
Originally Posted by tango2
(Post 52224609)
... I was carefull on putting on timing belt to keep in time if but if moved would that cause a code 52? ... look at timing or knock sensor
(Post 52224609)
... The old harness knock sensor had a single black wire shielded with outer wire mesh looking wire kind of like a coax cable. The new harness has two seperate wires a brown and a black. I was told to hook the black to black and brown to mesh...
I got a good running 3.0 low millage out of a 1989 truck.I put it in my 94 truck but all the wiring to computer was wrong connectors to ecu. So i decided to pull all wiring harness off the blown 94 and put on the 89. The knock sensor was good on 89 so did not take off lower intake to replace it. But did take off upper intake to replace harness and injectors The wire to the 89 knock sensor was the single blackwire with shielding and the 94 had two wires one brown one black i hooked the black to black and brown to shielded .
