YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   Code 12? (https://www.yotatech.com/forums/f116/code-12-a-247818/)
yeehaw1 Jan 18, 2012 06:40 PM
Code 12?
I pulled the check engine light codes, and got code 14 at first, then it threw code 12 twice, it never threw 14 again... 12 is a Knock Control Sensor Signal code from what i've read... 14 is an ignition signal...
skoti89 Jan 18, 2012 07:57 PM
I think when I was researching this on my 87 4r, code 12 is rpm signal. Which could be the knock sensor. But all my searching led to finding out very rarely does the knock sensor itself go bad. Its most likely a conection from the sensor to the ECU. check the pig tail. the sensor itself is on the passenger's side under the oild filter I believe.
yeehaw1 Jan 19, 2012 01:49 AM
I used the chart here http://www.troublecodes.net/Toyota/ and after double checking it, it could be Either the code I said, or the code you said... I been wondering where the dang sensor was for a while now, I'll have to check it...
Thanks for the info!!!
yeehaw1 Feb 20, 2012 08:51 PM
well, i redid the wire, and the light stayed out for about 2 miles... Guess i'm gonna have to change the sensor...
