Code 11 help
Old Sep 14, 2008 | 11:43 AM
86Crawler's Avatar
Exclamation Code 11 help
I need help diagnosing this code for the TPS. Its on a 1986 4X4 with a 22RE. Help with schematics or what wires to test to see whether its the TPS, TPS circuit or ECU would be nice. Thanks
Old Sep 14, 2008 | 12:12 PM
thook's Avatar
Is it a one digit code or two digit? Flash eleven times consecutively or a "1" followed shortly by another "1"?
Old Sep 14, 2008 | 02:18 PM
86Crawler's Avatar
it flashes 11 times consecutively
Old Sep 14, 2008 | 02:58 PM
abecedarian's Avatar
the code 11 means that the TPS is not signalling IDL to the ECU when the diagnostic connector is jumpered. this could be caused by the throttle not closing completely or not adjusted properly, or by the TPS not adjusted properly or malfunctioning, or by a fault in the wiring or ECU.
so first, you'll need to verify the throttle is closing all the way and that the accelerator cable isn't hanging up or anything like that which would cause it to stick. you might also want to spray some cleaner into the throttle body itself in case there is any gunk inside causing the plate to stick. once you've done that, clear your code by disconnecting the EFI fuse for a minute or so then see if the code returns. if it does, then check the TPS per the instructions here: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Sep 14, 2008 | 10:13 PM
86Crawler's Avatar
Thanks for the help!
Do u know anything on code 12?
Its about the knock sensor but the book I have doesnt explain how to diagnose it???
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
