Clutch squeals when pressed in half way
My 1990 toyota pickup recently started to squeal with the clutch pressed in halfway. When it happens the rpms drop and my electronics flick off momentarily. Using my clutch cancel start button seems to stop this from happening. Can anyone help me with whats going on? Thanks
Originally Posted by Bjorn Jensen
(Post 52351581)
Dr says, "well don't do that!" Seriously though, you'll want to give a more detailed description of what happens, when and what you are doing to reproduce the noise. In detail.. Just guessing it'll be the throw out bearing. |
Originally Posted by Co_94_PU
(Post 52351588)
Man says, "Hey doc, it hurts when I do this."
Driving starting stoped at lights hot cold yadda yadda..
I over looked the light thing as engine dragging but! Maybe you've pinched a wire some where and it's all coming from or related to something under the dash. Check everything is clear there, won't cost anything but time, same at the slave cylinder a few wires there also. Could be pinched starter wire and it's the starter trying to turn. |
bad pilot bearing maybe? dogging the engine hard enough to cause a voltage surge.
