Clunking in reverse
Old Feb 21, 2016 | 05:24 PM
NDcrawler's Avatar
Clunking in reverse
1986 4runner 22re 5 spd manual trans, drives and runs great in forward at interstate speeds, just as soon as I put her in reverse it has a not so good clunking sound? Constant as I am going backwards. In 2wd if I push in the clutch it stops and clutch out in reverse clunking? In 4wd hi or low with the clutch engaged or disengaged clunks either way? Any ideas?
Old Feb 21, 2016 | 05:29 PM
millball's Avatar
Damaged tooth on one of the tranny reverse gears??
Old Feb 21, 2016 | 08:06 PM
honota's Avatar
check your drive shafts...whens the last time you greased all your joints
Old Feb 21, 2016 | 08:53 PM
ZUK's Avatar
ZUK
Do you have a detroit locker?
Old Feb 22, 2016 | 06:16 AM
NDcrawler's Avatar
Oh, and by the way just bought her a week ago. Haven't checked the u joints or the drive shaft yet, that's what I'm hoping it is. Hope it isn't the tranny!
Old Feb 22, 2016 | 06:17 AM
NDcrawler's Avatar
Most likely not, unless toyota put them in at the factory? It is bone stock, even the origional exhaust!
Old Feb 22, 2016 | 02:03 PM
GO_BLUE!'s Avatar
Inspect & grease your U-joints.
Old Feb 22, 2016 | 06:15 PM
NDcrawler's Avatar
Well, had the wife drive it backwards and sounds like from the trans. Put the 4wd shifter in N and then the gear shifter in Reverse and still clunking, crawled under and felt the clunking come form the trans! Damn it! Thanks for all the info guys! Gonna drive her this way until I can buy a rebuilt trans from Marlin Crawler! Then change the output seals on the transfer case since I'll have it out as well! After the SAS will be putting in a dual case from MC.
Old Feb 22, 2016 | 06:16 PM
NDcrawler's Avatar
You were right!
eeTwidget
7
Jan 8, 2016 03:47 AM
DrivingTheAmerica
Dec 30, 2015 08:43 PM
79yotalongbed
Dec 16, 2015 05:45 PM
mizombie
3.4 Swaps
9
Dec 15, 2015 09:39 AM
dbbowen
Dec 3, 2015 12:48 PM
