YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   clearing codes (https://www.yotatech.com/forums/f116/clearing-codes-98113/)
943kgt Oct 26, 2006 07:32 PM
clearing codes
just wondering how to clear a cel code on my 95 22re??? thanks for the help in advance
rezrunner92 Oct 26, 2006 07:36 PM
Usually you can just dis connect the negative battery cable for a few minutes. Maybe step on the brake pedal for a few seconds while the battery is disconnected just to take out any residual power.
Elton Oct 26, 2006 08:49 PM
unhook the negative terminal for 15-20 mins
bigdirtdog Oct 27, 2006 01:40 PM
Pull the EFI fuse
Try pulling the EFI fuse in main fuse block and neg battery post. This works on my 94 PU and may wife's 02 Highlander. Good Luck
