Checking RPM with multimeter?
Hello!
I searched and searched, probably drove right past it, but I’m trying to figure out the correct procedure for using a multimeter to test RPM. Com to ground and red to distributer negative? I’m looking to get a multimeter with an RPM function and just wanting to know the right place for the leads. 86 4Runner. thanks! |
I know those are the correct connections for my old “engine analyzer” box with tach and it works on my 86 22re.
i have not used a multimeter with freq counter for this though.. |
I've used a meter with tach/dwell/volts. It needed power from the vehicle though so it had pos/neg/tach connectors. I guess you'll need a ground and then you can pick up the tach RPM signal from the IG port next to the under-hood diagnostic port.
2 Attachment(s)
Originally Posted by outatime
(Post 52462953)
Hello!
I searched and searched, probably drove right past it, but I’m trying to figure out the correct procedure for using a multimeter to test RPM. Com to ground and red to distributer negative? I’m looking to get a multimeter with an RPM function and just wanting to know the right place for the leads. 86 4Runner. thanks! That's what my Actron hand held meter says to do on page 11. |
| All times are GMT -8. The time now is 06:06 AM. |
