Check Engine Light Problem
Whats up guys, I have 93 Toyota Pickup 4x4 V6 with a 5 speed manual trans... I noticed the check engine light come on while I was on my way home earlier today, I came home and checked for a code and it constantly flashes at the same pace and didn't stop saying as if I nothing was wrong.... So I drove it around the block, at first the CEL was off and after about a minute of driving it came back on. So I stopped, checked again while the vehicle was running and nothing flashed it just stayed solid. So I turned it off checked again again it just constantly flashed with no delays or pauses....
Any ideas?:( |
Resolved the issue.
So, what was it?
You can't just say you resolved the issue and not state what it was or what you did to fix it! :pop:
Black electrical tape. :hillbill:
:wabbit2: |
Actually... youd be surprised what people will do to not see the cel... When I got my p/u I noticed the cel wouldnt come on at all, not when I started the truck, or even when I'd disconnect the tps... Turns out the moron that ownbed it before me had cut the wires to the o2 sensor (still trying to figure out why anyone would do that) and to keep from seeing the cel he pulled the bulb... When I got in there to check it out, the guy had pulled the bulb from the cel, and put it where the bulb for abs would have been if my rig had abs... lol
Took me quite a while to get that one resolved.... |
| All times are GMT -8. The time now is 06:59 AM. |
