Cheap muffler
I need to have a custom exhaust made, I moved the gas tank and shortened the wheelbase. Vechical is a 90 extra-cab v6, I was hopeing for something close to factory sound.I wouldn't mind a little more tone, but it had a cherry bomb before and I hated it.
Been looking at what summit has, Dynomax Thrush, Force Pro-Series Mufflers, and Summit Fully Welded Mufflers. Anyone run these with a 3.0? thoughts? thanks mike |
I have a dynomax with a highflow cat on my 3.0 4runner. Pretty mellow sound and I liked the performance gain but I really haven't tried any of the others to compare it with. It's held up well to salt and I think it's on the cheaper end of the options.
cheers |
Thanks for the quick response. From searching seems like alot of the aftermarket stuff is the same. I'm looking for the most conservitive out of the bunch. I heard borla is probably the closest to stock, but its almost $100 :scared:
the dynomax is still louder than stock. Why don't you get a stock exhaust and cut the pipes doen to fit? How much did you shorten the wheelbase? I assume there is no box in it now - you could do stacks
You may be able to get a factory muffler from the dealer. Dunno if it would fit, now, or how much it would cost, but the sound should be correct.
Mike in AR |
Box? no bed it has a flatbed now. Not really into the stacks, plus I have a truck box right behind my cab. |
Does anybody know what the stock wheelbase is??
I know on the runner a factory muffler replacement comes with everything from the cat back. I would imagine this would be the same as the truck. |
I think its something like 124"
You can easily cut 6.5" out of the stock exhaust at any location. There is enough stright pipe in it to do it before & after the muffler
for a cheap muffler glasspacks are great....but they are loud haha
