Can't get a pulley from toyota, they say it doesn't exist.
1st.
My air conditioning belt goes around the crankshaft and another pulley. In some 4runners there is an air pump...? I don't have an air pump. I have a pulley. They say that this pulley doesn't exist in their part books. Anyone able to help me out on a part number or even giving it a name. They tried to give me the adjustment pulley off the timing cover. I have a 1986 4runner. Second There is a arm that attaches to the left side of the engine facing it and extends up and to the left of the engine just below the plenum... I can't see anything that it hooks to... its about pipe an inch thick and about 2 feet long any clues... thanks guys. |
I had a similar situation with the 3.0 in my 89... I LOVE the place I take it to and they told me it is a dealer only part. According to them, its called the Fan Pully Bracket and dealer Part # is FBA200
Hope this helps!! |
Originally Posted by jluce
1st.
My air conditioning belt goes around the crankshaft and another pulley. In some 4runners there is an air pump...? I don't have an air pump. I have a pulley. They say that this pulley doesn't exist in their part books. Anyone able to help me out on a part number or even giving it a name. They tried to give me the adjustment pulley off the timing cover. I have a 1986 4runner. Second There is a arm that attaches to the left side of the engine facing it and extends up and to the left of the engine just below the plenum... I can't see anything that it hooks to... its about pipe an inch thick and about 2 feet long any clues... thanks guys. The bar your talking is just a support for the plenum .... it mount to the engine mount and to the plenum . I think this is the bar your talking about in the pic ... http://www.members.shaw.ca/slacker50...uildparta2.jpg and here it is mounted . http://www.members.shaw.ca/slacker50...s/IM000474.JPG as far as the pully .... I think they call it an IDLER or tensioner . |
try knocking the bearing out and getting a replacement bearing from someone other than the stealer. they can order the entire unit for $$$, the bearing might be less.
lee |
Napa p/n 38036 is what you need I am pretty sure.
