Cam Sprocket Bolt
My first time around i was spoiled and had air tools, does anyone have any tricks to getting it off with hand tools ??, thanks.
Is the motor in or out? if its in, put it in gear and get a cheater bar.
*for a 22 |
Got the BEST way your going to hear 100 people say 100 different things and im also ASSUMING its a 3.0... half way down your cam is a spot for a whench its a 1 1/16 size then take a regular socket on the front have a buddy hold the wrench
Look at pic, i know i used an impact but i didn't need to..... http://i100.photobucket.com/albums/m...6/PA130054.jpg |
Yes, 5th gear and 4wd engaged will seem to be the ticket here, my only problem is that the engine still turns, so it doesn't stay at TDC. That said, it was 2:30 in the AM, and i most definitely forgot to add its a 22RE.
i used a chain wrench and it worked great
