YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   brake and charge light on (https://www.yotatech.com/forums/f116/brake-charge-light-182199/)
neq0323 May 15, 2009 04:18 PM
my brake/charge light are on and my battery is new alternator test good and is charging at 14.53v-14.55v. however i noticed on my 7.5 amp charge fuse both sides have low low voltage .003-.013. any ideas? truck runs great but light is on. thanks p.s 87 4wd 22r
bugs1961 May 15, 2009 04:29 PM
This thread describes a problem like yours: https://www.yotatech.com/forums/f116...glitch-182108/
You have a wiring issue, blown Alt 80 amp fuse, or a bad alternator.
mattaway May 15, 2009 05:16 PM
my truck did that when the alternator was on it's way out....
neq0323 May 15, 2009 05:46 PM
did you loose power at the charge fuse?
mattaway May 15, 2009 07:42 PM
i never tested anything. i knew it was the alt. when it went bad. the truck died at a redlight and wouldn't take a jump.
DupermanDave May 16, 2009 04:54 AM
wish my truck warned me when my alternator went out. It died suddenly and left us stranded on a cold, rainy night.
