best spark plugs for The 3VZE
i ussualy get bosch platinum single spark on my 1991 4runner is there something better??
The Germans (Bosch) and Japanese (Toyota) don't get along so well since WWII.
Just get "regular" (ie no platinum, iridium, splifire, yadyada) NGK or Denso plugs and make sure they are gapped properly. Be sure to do the cap/rotor while you're at it. If you use carbon core plug wires, do them too. |
Very happy with my NGK V-power.
NGK is the only way :bounce:
Originally Posted by Poul D'eau
(Post 50741998)
i had v power and it worked like , put in the regular cheapo copper cores and it worked better....oh yea...i never gapped the v's and gapped the cheapo's ...... i like to learn the hard way, v6's suck :)
Originally Posted by tc
(Post 50741990)
I swapped from bosch platinums to regular old NGKs on the advice of yotatecher's and there was noticable improvement in idle quality. this was a while ago though, I can't remember the part number for the plugs
oem denso or ngk's
NGK v power FTW
Originally Posted by 89whitetoyota
(Post 50742061)
Horohito had a problem with Hitler? Wasnt Stalin, Hitler, and the Rising Sun all on the axis powers? Anyway, I use motorcraft, and have had no problems.
i have ngk irridium plugs on my 4runner and ever since i have gotten a smother ride, and better gas mileage. i think with newer advanced plugs you gotta get new wires too though.
my friend put bosch plugs in his 98 taco and he had a horrible miss after, then he put NGKs in and it went away and i run NGK iridium plugs in mine.
(Post 50741990)
Just get "regular" (ie no platinum, iridium, splifire, yadyada) NGK or Denso plugs and make sure they are gapped properly. Be sure to do the cap/rotor while you're at it. If you use carbon core plug wires, do them too. Use regular Denso plugs K16TR11 and you'll be fine for 25-30k miles. Bosch platinum plugs suck. At least the garden variety 2/$5 ones suck. The good ones cost more than NGK/Denso platinums. |
ngk/denso here.
Originally Posted by 86tuning
(Post 50742248)
+1
*hijack*
What about spark plug wires for the 3.0? Is it best to stick with 5mm or move up to 8mm? Brand? Napa has some I have been eying... *end Hijack* |
The thing with plug wires is to get real metal core wires, NOT carbon core. Carbon is not intended to be flexible and eventually little cracks will form in the conductor and you'll lose ignition "power" because the spark is jumping all those gaps. So, you have to replace them periodically.
IMHO, the oversize wires are a waste - you're carrying a lot of voltage, not current - a little conductor is plenty. |
My NGK iridium's have been in for a year (first time irdium user) & my fuel economy went up by about 1 m.p.g. when I installed them; they've been trouble free so far. The regular NGK's or Densos would be fine too but if you want iridums, they will work. They're expensive but if you know that ahead of time it's no biggie.
whats the proper gap for the 3.0?
