best mud mod
other than tires of course, whats the best thing to do if ur gonna mud? suspension lift, body lift, cam, etc? and links to sites with prices and such would be great.
edit- PICS of mud make me happy |
lockers...
x2 on lockers
ok, sooo, any sites? and this is a 2wd pu. prices on lockers?
4 wheel drive
mudding in 2WD??? Is that possible?
oh ud be suprised. its 90% driver guys.
Originally Posted by dijlop
(Post 50508552)
Sorry no its more like 60% driver. I got myself burried in a mud hole today bad and there was nothing I could have done taking the same line. |
i stand by it. 90% driver, 10%truck, 50%pit. lol. yea.the pit ur in fills an entirly different void of how to get through.
Mud tires + lockers
ok, so lockers are a biggy. now between a body lift and a suspension lift, based on price and mud ability, which is better?
BL, cheap to fit big tires but only the change in tire size affects your clearance
Suspension, expensive but will give you more clearance up front for IFS |
yea. are there any suspension lifts for my truck that are less than the ones i found for $580? and if not, is there a way to do it piece by piece for cheaper? and i plan on doing most of the work myself.
(Post 50508562)
and mudding isnt 90% driver...its a 50/50 split, you need a capable rig and a good driver to do any sort of responsible offroading... |
And make sure you check out the mud pit and how thick the mud is first.....I found that out the hard way, look at my avater :chairfall
mudding...responsible offroading...mudding...responsible offroading... i think those dont fit that great. safe offroading, yes. responsible? out of that 90% thats driver, 50% is experiance. the other 40 is knowing ur vehicle. i would take someone thats mudded for many years in a little truck sittin on little wheels, with a little engine, over some kid thats never seen mud before in a skyhigh f250 on massive wheels and such
Originally Posted by 89silverpu
(Post 50508583)
If I was going to mud a 2wd, I'd lift it high enough to run at least 33" mud tires, do a rear axle swap to one out of a 4wd with 8" ring gears and a stock 4.10 ratio, add a locker and go to town with it.
At that point you've done all to it that you can. Then when you get tired of getting stuck buy a 4wd. You'll still get stuck but you'll get twice as far in to it before you do as a 2wd truck... |
Personally I would take the kid with the F250 4x4...
We can get righteous in our little Toyotas, rightly so, but not TOO righteous... |
when play around in the mud with my truck with just the locker and it does fine so i would say lockers and tires
| All times are GMT -8. The time now is 06:25 AM. |
