Banjo bolt size on cold start injector?
Hi all,
Does anyone know what size the banjo bolt on the cold start injector is? I'm looking to get a banjo bolt adaptor from Actron to test my fuel pressure.
Bolt measures 7.7 mm x 19 mm.
Head takes a 12 mm socket.
Hole is 5 mm from bottom of head or 14 mm from end of bolt.
This is from a 91 V6.
Could you post the link to the adpater if available?
You forgot to include its weight, lol, jk
Ok, now that you gave me the dimentions of the thing can you give me the tread size. Actron sells banjo adaptors for their fuel pressure tester on their website. Here's the link:
http://www.actron.com/product_detail.php?pid=16173
the adaptors are listed under accessories. They have M8x1.0, M12x1.5, and M12x1.25.
Hey Cilo. I have been interested in getting that same pressure tester. Would you mind letting me know if you find an adapter that works? The reason I didn't order it is because I was not sure if the adapters actron had would connect to the banjo bolt fitting on the manifold. Thanks!
This doesn't help the banjo discussion, but I found it a lot easier to remove the fuel rail and drill/tap a 1/8 NPT fitting in the end of it. Easy to use with almost any pressure tester or electric sender.
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
Jnkml
07-06-2015 01:20 PM
