YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   bad miss (https://www.yotatech.com/forums/f116/bad-miss-133690/)
doubledizzle Jan 1, 2008 06:55 PM
bad miss
ok need major help.....22re not doin to well, went for a swim the other night and it stalled as soon as i hit the water which i was expecting it to..but once i got all the water outta everything it runs but now its like it has a miss backfires all the time and you can feel it....pulled the plugs and number 4 was burnt rich so i changed them and cap/rotor still same miss and still foulin up number 4?? some one please helllpppp!!!!......also had to get a new idle control valve (old one has been shot for awhile) and now it wont make up its mind about idle it will run fine sumtimes and then sometime when i come to a stop it just stalls out ive adjusted the air fuel mixture many times and just cant get the happy spot so if any knowlege pleasee help me! thanx so much guys
toytech76 Jan 1, 2008 08:04 PM
Did you suck any water in the eng? Maybe you bent a rod if you did. Make sure all water is out of anything electronic
