Bad AFM ?
Been having a lean misfire once warmed up lately, does fine when cold... closed loop. Was advised to change AFM, figure after 30 years and 800k plus miles couldn't hurt, right ? Got the remanned unit today put it in, start it up and its missing belching black smoke ,,,,, WTF ? Even thru the CEL ! Swap the original back on, no smoke, CEL goes out on its own ! What am I missing. have another AFM coming in Thursday .
Advised to change the AFM ... why?
What are the symptoms of your miss... at idle, certain rpms coasting down hill and barely touching thre accelerator?
what engine 22re or 3vze |
I don't think they change the circuit board on remanned ones. I just ordered one since I had some dead spots on the restrictive strip on my orig one. Remanned one had more dead spots than mine so it is going back. Here is how you test you AFM: http://htftp.offroadsz.com/marinhake...33volumeai.pdf
Once warmed up and goes into open ? Loop. Coasting downhill it gets a barely noticible back fire once in a while, Does not throw a cel. On a 22 re , when cold it does not have the misfire, sounds nice and even out exhaust . |
A lso, once warmed up it has the pop pop out the exhaust, can feel and hear it as well, cold nice and even |
When was the last time you adjusted your valves?
3000 miles ago when new head was installed |
Put second replacement on, runs better then it was. this one however has some kind of adjustment on it. original and first one did not, any ideas ?
Originally Posted by 87-4runner
(Post 52418883)
Idle control air valve would be my guess.
(Post 52418883)
Originally Posted by Blue 89 Runner
(Post 52418888)
(Post 52419709)
Seems like it is slightly getting worse.... IAC was changed out a while back due to not returning to low idle, could it cause the erratic misfire at idle somehow ?
Open loop is when the engine is cold and closed loop is when the engine is warm. Unplug the O2 sensor and see if it still has the same symptoms. Unplugging the O2 will force it into open loop and will determine if the problem is related to corrected fuel trims.
Oxygen sensors do wear out, so that is a good place to look.
Lets go back to the Air Flow Meter for a moment. I am unsure how much the AFM plays a role in the problem you are experiencing (there are many potential causes), but it would be good to know if the Air Flow Meter is working properly. Do you have a multimeter and know how to use it? If so, the Air Flow Meter can be electrically tested to make sure it works as it should. Here is a good write up on testing the Air Flow Meter using the Factory procedure: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml :safari: |
Check your intake tube between the AFM and throttle body for cracks or tears. Leaks can cause missing and rough running. It is a quick and easy check. Then test the AFM as old87yoda has recommended.
Originally Posted by Kolton5543
(Post 52419734)
(Post 52420257)
Unplugged it and still acts the same... with the addition of the CEL of course. So, this tells me what now.... o2 sensor is good, correct ?
Check the iacv and both coolant sensors and make sure they are functioning properly. If you're having a cold loop hot loop problem that's where I would start. |
Originally Posted by yota tay
(Post 52420261)
Yep.
(Post 52420262)
All the IACV does on these is speed up the idle when cold, correct? What is the proper method for testing these. Packed up repair manual in storage till I get moved , TIA
