Automatic transmission dipstick 3vz
1994 4Runner 3vz
What can prevent the transmission dipstick from being pushed back in? Can I drive without the the dipstick? I have this problem every time I check the level. This time it does not want to be pushed back into the tube. Thanks for any assistance ... |
put it in...pull it back out...rotate it...put it back in...repeat that process til it goes all the way in
I am gonna catch hell for that wording too... :flush:
i usually have to twist mine round a bit to get it to go in that last little bit.
can you drive without a dipstick? yes, and no. you dont have to have a mettal stick shoved down the hole, but you probibly want to cap the tube so you dont get crap down into the trans. so get an extra dip stick and cut the end off and use it to cap the tube. |
it does take a little finese, but it should be kept installed. not likely to be any obstructions, just funky angles down the tube |
Dipstick twist
Thanks to all ...
The twisting of the dipstick does the trick. |
Originally Posted by eric-the-red
Sounds like something from 'Sex for Dummies'
I knew someone would find it amusing :pat:
I find most things amusing, if you're not laughing you're not living :D
