ARB Snorkel on 93 22RE pickup?
I'm kind of confused as to why ARB doesn't make a snorkel kit for the 22RE's, what's up with that? I hydrolocked my engine yesterday splashing through a puddle a little too fast and don't plan on having this happen again. Luckily no damage. Searching through other posts I found one other person who did an ARB snorkel on a 22RE but I'm not sure which kit he used. I don't want to be paying for too many parts I won't even be able to use like their airbox or whatever they come with. Seems fairly simple to pipe the stock efi airbox to the snorkel I'm just not sure if ARB makes just the outside of the vehicle parts kit.
You can make your own out of PVC piping or ABS.
im pretty sure Safari makes one for the 22re, but i might be wrong.
i know they make one for my 3.0L in my 88 p/u and it is around 300 bucks cost |
Spend 300 or so or make it yourself outta ABS pipe, some black plastic textured spraypaint and the safari head for about 100 bucks at most.
Course I made my own for my T100 and I LOVE IT. If you do use the safari any one will fit, even the V6 model (assuming its on the correct side. All you gotta do is get some kinda tubing to match it up to your airbox or the tube itself. Use some silicone sealant over the seams if you want and your good to go. |
