Another head gasket question
i did a body lift on the truck and i drained the coolant from the rad. i put the coolant back in and the truck started to overheat in 5-6 mins. i didnt know what to do. a mechanic told me to take out the thermostat put the coolant back in and run the truck for like 10 mins, then take off the thermostat housing making sure all of the coolant doesnt run out of the bottom rad hose. then install the thermostat and fill up the rad. i did that and it solved my overheating problem. the system was full of air
The funny thing is (or not) i had about a week ago told my son i would never own one with the 3.0 ! but this truck came long and the price ( i think ) was right its in pretty good shape for a 94 and being up here in VT , the cab is pretty much rust free there is some around the rear wheel wells but it has a new toyota frame under it new brakes, new shocks,all new brakelines ,master cyl. and booster same for the clutch, new front a arm and it goes on, so was hoping something easy and cheap to fix should have none ! I did or was think i might try taking out the t-stat and see what would happen but its still funny as hot as it got it never pushed any heat out of the heater ,if it got that hot woulden't it heat the air coming out of the heater too ?
#26
What should the idle be set at ? i know not 2000 but would like to get somewhere close to what its suppose to be.
#28
any clue as to why when it got hot there was no heat coming out of the heater ? it would make since woulded it that if it got so hot it was boiling over that there would have been heat right ?
#30
thats the thing i have been try to figure out , but no coolent leak on the outside of the motor no coolent in the oil no smoke just 10mins of running on a cold motor she's in the red and boiling out its got a lot of back pressure both hoses where hard so ???? some are leaning towards a water pump but still would it give heat even if the pump was bad ? or would it get through the system with a bad pump ?
#33
Do you guys think it would be worth taking the t stat out and trying it with out in and see if it boils over or gets hot ? then if that doesn't make a diffrent's try a new water pump ?
#38
Ok we pulled the tstat out filled it back up and started it, it seems to be flowing through the radiator good let it run a good 15mins and never boiled over the temp. got up to about a 1/4 took it up the hill and back and maybe gauge got to 1/2 but never boiled over the hoses didn't get hard had some pressure in them BUT this morning we checked the radiator and it was down maybe a quirt or less ? anyhow could not find any leaks and oil still looked good also did a pressure check and it never lost any pressure , started and let it run awhile again today still seemed good no smoke no leaks and nothing in the oil so where can the water be going ? and do you think it was or is just a bad aftermarket tstat ?
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
