air bubbles in clutch master cylinder reservoir
hello
i neep help.. i keep on getting air bubble in my clutch master cylinder reservoir i also have some black sut at the bottom of the reservoir what is that ? seal? and a little chatter too when taking off from a dead stop i have bleed the system ,but i keep on get them in there where is the air getting in ? the slave cylinder? or the clutch master cylinder? the petal feels a little funny. let me know thanks |
could be getting in from the clutch master itself, but if there is air getting in, then there should also be fluid coming out...so look for a leak.
care to go through your bleeding technique for us? what does "pedal feels a little funny" mean? you could have a cracked line? |
theres is no fluid coming out anywhere..
no leaks the fluid in the reservoir is not going down at all. the petel is soft sometimes and sometimes a little stiff getting a little chatter |
