Adjusting the AFM
I've read posts of members doing this and wanted to share this info from DowneyOffroad and ask how those of you have done this handle Warning #4 on this adjustment procedure.
MASS AIR SENSOR MODIFICATION* * Tampering not legal, should only be modified for racing use. http://downeyoff-road.com/EngineComp...ion/FI_002.jpg The following adjustment can be used to richen or lean the air/fuel mixture from the factory setting. This adjustment could be necessary when using a Big Bore Throttle Body or other EFI modifications. The mass air sensor (MAS) is found on top the air cleaner canister on 1985-95 Toyota vehicles. The sensor is an aluminum housing with black plastic lid. Cut the seal holding the black plastic lid in place. Gently pry the lid from the housing. To adjust, first mark the original location of the hold-down clamp on the gear wheel so you can return to stock setting if necessary. Loosen the clamp screw and rotate the gear wheel a few teeth as necessary. Clockwise leans the mixture, counter-clockwise richens the mixture. After adjustment, replace the top plastic lid (see Warnings below). WARNING #1 - Use caution when cutting the top lid seal with a hobby knife so that plastic lid is not cut or damaged. WARNING #2 - DO NOT let spring loaded gear wheel unwind, you will not be able to find stock setting/home base. WARNING #3 - Ensure you establish a good seal when replacing top lid, moisture can destroy the sensor electronics. WARNING #4 - DO NOT use an adhesive which creates a gas or fumes when drying, fumes will coat and destroy the sensor electronics – you’ve been warned! If no smoke, what do you look for? |
Wait a carb running rich with an AFM...? :think: As for warning #4, Sensor safe Silicone sealant, AKA: RTV. :dj:
Basic RTV is acetic cure and NOT to be used. If it smells like vinegar, don't use it.
Otherwise, sensor-safe sealant should be fine. As for rich/lean, EFI can do it too. The symptoms are mainly the same between the EFI and carb as well- stumbling, black smoke, crappy throttle response, misfiring, etc. If you adjust the AFM, keep in mind that the ECU will use the O2 sensor and will override your AFM settings during normal operations- you'll only see a significant change in mix at idle and at wide open throttle. |
Emphasis on the "dont let the gear/spring unwind" bit. I let mine unwind a bit, but I got it back to a normal running state. Right now it's not too lean and not too rich, so it's as good as I could get it by sound and smell.
Wish there was a way to get it back to factory so I can sleep soundly at night. |
You know, I'm not sure if adjusting the AFM really does anything. The ECU is a closed-loop system and it's going to see that the mixture has changed and compensate for it.
Originally Posted by InternetRoadkill
(Post 51042420)
Anyone fine tune the CO with the screw on the AFM?
VWs have the same Mass Air and we used to have to tweak them all the time to pass emissions. |
my 78 and 81 Scirocco's had nothing similar at all. ;)
oh woe the days of k-jetronic: adjust the fuel distributor to a 50% duty cycle on the frequency valve and be done with it... weep, weep. |
^^^ No doubt huh? How long is the list of cars that came with Flapper Mass Air meters?
Closed loop?
(Post 51042420)
Originally Posted by niQ
(Post 52465263)
this is affecting my rig generously. It has an egr delete and new motor and it will not run at the stock maf/AFM position at all. You run it up way rich and that’s the only way it’ll run. And then it surges in rpm’s up to 2 grand down to 1 grand over and over and over. Tell me why. I’m so irritated. Brand new motor and it won’t even run right. LcEngineering EGr delete kit. Also the idle screw on the throttle body? Hah. Does nothing. I’ve taken throttle body apart, cleaned the whole thing. Readjusted the tps. Please for the love of god tell me what I’m missing
Originally Posted by Danson
(Post 52465266)
Have you replaced the idle screw O-ring? Sounds like you definitely have a vacuum leak somewhere. Cleaned the IAC? AFM isn't your problem, adjusting it to compensate and richen everything up is just masking the actual issue.
(Post 52465267)
Honestly I traded my truck for this 4runner he put a brand new motor in it with new headers and exhaust all the way back precision injectors LCEngineering EGR Delete. This is my first ever Toyota. I cleaned the whole throttle body and put the tps on to where i thought it was when i took it off. i didnt know the idle screw had an oring cause i havent brought it out that far. all the vacuum lines that were taken off for the egr delete most of them were plugged/capped off i went around with carb cleaner and didnt hear much of a change in rpm's because of the surging when i richen it up or it dies when the AFM is in the stock position. honestly about to take it to a shop ive never had this much if a problem before
sounds like you may need to look into adjusting the TPS. https://www.4crawler.com/4x4/CheapTr...PS/index.shtml |
Have you tried tuning the AFM based on the O2 sensor voltage with the truck in open loop? How about any of the older posts from 2009?
Originally Posted by Bizzle84
(Post 52470683)
(Post 52470683)
Have you triedtuning the AFM based on the O2 sensor voltage with the truck in open loop? How about any of the older posts from 2009?
I would like to know also
I hope you realize that "tuning" the VAF doesn't do anything. I know that there are plenty on this site who will tell you that adjusting the VAF "only two clicks to the right" (or was it to the left?) made the sun shine brighter and the birds sing sweeter. But it just doesn't make any sense at all.
Nominally, the VAF tells the ECM that the engine is sucking "14 poohs" of air. The ECM looks it up in the table, and decides the engine needs "1 piglet" of gasoline, which it controls by setting the injector open-time. All done? Not so fast. How do we know your VAF is calibrated correctly? How do we know that setting the injector open-time to 1.2msec is "1 piglet" of gasoline? Just the temperature of the gasoline makes a difference! Add in wear and tear on the FPR, injectors, induction plumbing, etc. But the ECM knows! The O2 sensor (working in closed loop) tells the ECM that everything is running a tad rich. So the ECM backs off the gasoline just a tad. And to avoid doing this every few milliseconds, the ECM remembers this adjustment in the form of short term (and long term) fuel trim. All the calibration wrapped up into one adjustment. So let's say you've heard you can turn your truck into a fire-breathing (and polluting) dragon if it just runs a little richer. So you set the VAF three clicks to the left. Then, when it's really sucking just 12 poohs, the VAF reports it's sucking 14 poohs of air. The ECM sets the gasoline to "one piglet," which is actually too rich for the 12 poohs of air the engine is actually sucking. Whoo Hoo! Enormous power (and clouds of black smoke)! Uh, no. Again, the O2 sensor is on the job, and finds that all these settings are making the engine run too rich. So the ECM resets the fuel trim to make it right. And all the fussing you did with the VAF was a waste of time. Leave the VAF alone. If your engine is running rich, or lean, or else where, it won't be fixed by messing with the VAF. |
Originally Posted by scope103
(Post 52475877)
Nominally, the VAF tells the ECM that the engine is sucking "14 poohs" of air. The ECM looks it up in the table, and decides the engine needs "1 piglet" of gasoline, which it controls by setting the injector open-time. All done? Not so fast. How do we know your VAF is calibrated correctly? How do we know that setting the injector open-time to 1.2msec is "1 piglet" of gasoline? Just the temperature of the gasoline makes a difference! Add in wear and tear on the FPR, injectors, induction plumbing, etc. But the ECM knows! The O2 sensor (working in closed loop) tells the ECM that everything is running a tad rich. So the ECM backs off the gasoline just a tad. And to avoid doing this every few milliseconds, the ECM remembers this adjustment in the form of short term (and long term) fuel trim. All the calibration wrapped up into one adjustment. So let's say you're heard you can turn your truck into a fire-breathing (and polluting) dragon if it just runs a little richer. So you set the VAF three clicks to the left. Then, when it's really sucking just 12 poohs, the VAF reports it's sucking 14 poohs of air. The ECM sets the gasoline to "one piglet," which is actually too rich for the 12 poohs of air the engine is actually sucking. Whoo Hoo! Enormous power (and clouds of black smoke)! Uh, no. Again, the O2 sensor is on the job, and finds that all these settings are making the engine run too rich. So the ECM resets the fuel trim to make it right. And all the fussing you did with the VAF was a waste of time. Leave the VAF alone. If your engine is running rich, or lean, or else where, it won't be fixed by messing with the VAF. so how do i fix this issue then |
(Post 52475878)
| All times are GMT -8. The time now is 04:23 AM. |
