AC low pressure part#
93 Toyota V6 automatic with factory air. NOt finding replacement AC low pressure switch located in evaporator housing. Yes I am sure the switch is bad and needs to be replaced, it is leaking gas through the electrical end.
It says Denso 8505, no such animal, I did find a 4 Seasons/Murray 35829 but the electrical connection looks different. Any input greatly appreciated. Jim |
This site: http://www.toyotapartsoverstock.com/...rimLevel=18292 lists three different part numbers, some relating to what is called "dealer option."
I suggest you put each part number in google (add the hyphen), and see if you can find a seller with a good photograph. |
Sometimes parts were never released to the public even though it has a manufacture part number.
The important parts are the threads and the pressure the switch trips then catalog pictures can be general pictures not what it really is. |
