A340H temps
Old Oct 13, 2006 | 09:29 PM
  #81
thefallman's Avatar
for some reason this thread isnt appearing correctly sometimes i see all the posts sometimes not. sometimes there are 3 pages sometimes 4. its wierd
anyway Hydralic oil that is to cold will be stiff and shift harshly. the hydralic oil isnt in the transmission to be a lubricant but it is a secondary perpose and does perform that function to many parts. if kept below a 170 degrees your transmission bearings and other parts that need lubricant such as pump and other things will wear early.
this was covered earlier. 170 degrees is the tempature that oils perform best at and below which you get 80% or more of the wear and tear on your drivetrain.
So the faster you can get your Drivetrain up to 170 degrees and maintain a median tempature of about 180degrees the less where and longer oil life you will have.
Old Oct 14, 2006 | 06:55 PM
  #82
trythis's Avatar
Thanks for clarifying, sorry about yesterdays comment, I was pretty crabby fo rsome reason.
coryc85
Dec 5, 2015 08:42 AM
bradahman
Oct 1, 2015 09:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
--Oz--
Sep 6, 2015 01:06 AM
