a340h to r150f tranny swap.
I am starting to plan out the tranny swap on my 89 v6 4runner. I have been searching for threads for a while and have found some decent information. One thing I haven't found is an exact list of what is needed for the swap and what complications I will run into. I have seen 3 different threads with 3 different lists of parts needed. One even said the engine harness needed to be switched.
Has anyone done this swap personally that can explain a little of the process and list the exact parts needed? Thank you |
:coffee: Do your self a favor Buy a complete parts vehicle.
All the used parts you plan to use . Like the rear drive shaft crossmember / Transfer case Transmission Bell housing and Clutch fork. save hours running for the parts we tend to forget New Clutch kit and Hydraulics |
