95 V6 fuel filter and hard lines
Been reading about the fuel filter woes of working with the 4R fuel filter. Tried everything suggested to remove the absolutely rust frozen lines from the old filter. Probably never been changed. Has anyone paid to have the hard lines replaced? Cost?
Thanks for the help. |
Just how did you try and break those Banjo bolts loose
The break loose pretty easy it is just getting to them that is a challenge :jessica: |
Does the '95 have banjo bolts? My '94 has regular brass flare nuts. https://www.yotatech.com/forums/f116...ctures-218962/
Missed the V-6 part they would have the flared connections.
I am so used to the 22REC engines I just was not thinking:welder: |
