93truck 22re swap into 88 4 runner
Blew the motor in the 88 4 runner 22 re. Got a 93 22 re cheap to drop in out of a pickup. Both manual. What all needs to be changed? I know injectors. Couldn't find a thread to help me enough. Put the 93 in and piddled around ( I'm not good with wiring yet) turn the key over and get nothing except a click on the starter relay on the passenger side fender? Where do I need to start checking an swapping
Did you swap the TPS from the older motor to the 93 or did you change the wiring?
Did you use the starter from the 93 or 88? Could the starter be frozen or need new contacts? What wiring have you hooked up? |
wanting to use the 93 wiring hrness on it. seemed like itd be easier at the time. and I used the 93 starter..i just need to know what is different on the 93 body and the 88 body so I can make them match up.. and where to find wiring diagrams too
and I have the wiring harness to the 93 motor hooked up to it still and dropped the motor in.. not everything plugs in tho
it would be easier to keep the 88 harness in place. Just swap the injectors and TPS from the 88 onto the 93. It makes sense that the motor won't turn over with everything unplugged. Even if it did turn over, it wouldn't run.
There are links here on Yotatech and on Pirate4x4 that have the PDFs of the factory service manuals. Thats what you'll need. |
Alright I'll do that. I got a wiring diagram today. So I'll be good now. It's my buddies 4 runner and he messed it all up doin it himself and stuck me with it haha
