93 lift help appreciated
I've got the rear sag and would like to fix it and then some. I've got a bull bar on the front- no winch. I'd like to get a 3-4 inch lift all around- I will be doing moderate off roading, nothing too crazy. Here is what I'm planning. If anyone has any suggestions, they would be much appreciated and welcomed.
Front: 1.5" Ball Joint Spacers 2" Coil Spacers Torsion bar- OME Bilstein Shocks- I ordered theBLS-BE5-6582 Front Shock (3-4" Lift REAR: - Springs- OME 901 HD Coils- will they lift up the rear 3-4 inches or should I try to hunt down som FJ 80 springs - Shocks- not sure about shocks for the rear-the OME n71E (the FJ80 shock, or the OME) seems to be recommended for a 3-4 inch lift.initions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> - Panhard drop brackets Thinking about the steering stabilizer up front as well. Thanks alot. |
What size of tires are you planning on running?
31's for now, maybe 33's later.
uhm uhm uhm..you don't have coils to space in the front :) and thicker t-bars won't really give you lift, they just have a higher spring rate.
Also, look into an LSPV lift bracket. Load Sensing Proportioning Valve. |
I have pretty close to what you want to do. Here's how it looks. Here's a full write up.
ome 901hd's will give you 3-4" over sagged springs. Only about 1.5-2" over new stock. http://www.jamesdeancreations.com/4R...g%20Before.jpg http://www.jamesdeancreations.com/4R...ng%20After.jpg http://www.jamesdeancreations.com/4R...olding%203.jpg |
true but for 31s you dont really ned a lift.. money for armor lockers.. winch....
but if you like the look of a lift do it! but stock ifs is most reliable |
