92 4run questions
Hey man I am stuck My toy will start but once I step on the gas to start off not hard just normal, The engine light comes on? TPS sensor? the truck runs fine for the first 1/2 hr then it will stall or stumble "loop" if you will even while driving. the truck is retarted on gas I mean 30$ @ 98.6/litre gives me about 150km and I'm lucky if I get that I put new Plugs Bosh4, Wires, cap, button, K&N filter checked the rubber intake hose and collector boxes for holes, none. Seems to have even compression, The map sensor checks out any ids guys I am stuck
just a comment the air bags for the coil springs in the back of these bad boys are a wicked and easy mod for towing and body roll while driving
o god bosch plugs get those out of ther asap
http://i154.photobucket.com/albums/s.../truck2183.jpg
i think this pic speaks for itself:bounce: |
does the check engine light stay on?
o yea, only put ngk or denso in there
i 2nd the bosch plugs.they are junk in a japanese anything.get em out now!!!
thank you guys I will try it and get back to you
i've come to find out it is the knock sensor (code 52). when I traced the wire, I found it was cracked and corroded just below the intake, where it comes out of the block (between the connection and block). Any suggestions on how to fix this?
| All times are GMT -8. The time now is 12:15 AM. |
