90 pickup slipping into 4wd
Old 01-24-2010, 05:01 PM
93YotaMonster's Avatar
hey guys a buddy of mine drives a 90 Toyota pickup sr5 with the 3.slow and automatic transmission, here recently he's been having trouble with his truck slipping in to 4wd. the leaver keeps sliding back and going into 4wd, so i was just wondering if there is sum type of bushing or anything in there that has went bad and keeps letting it sliding back into 4wd?
Old 01-24-2010, 07:06 PM
fireman1559's Avatar
from what ive seen with mine what could be going on is that the shifter could be so worn out that it just falls into 4wd. does he know if it is going into 4wd. see mine was loose and slopy(no not what yall r thinkin u sick puppies) and would drop into 4wd very easly if yall are to take the cover off that hides the shifter and 4wd shifter and see whats loose in there next place to start lookin would be on the xcase 2 see if the connector is loose and you can tighten it up
Old 01-24-2010, 07:41 PM
yeah he knows wen it gos in, cause the light will come on and you can feel it grab.
ok i will try to take the cover off tomm and look at it and see what i can do.
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
Roger Borba II
07-09-2015 05:05 PM
cyclist231
07-07-2015 12:56 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 90 pickup slipping into 4wd
