89 3.0 No Power until 3,000 RPM
-----SOLVED
This is my first post, found this forum doing some research. I recently picked up an 89 3.0 V6 from a friend for a good price, just broke 300K but has been running like a champ. Until recently it has no power through 1st and 2nd gear and I have to run it up to 3-5K rpms to get it to start moving. No check engine light. It still drives I'm just ripping through gas though, and it takes a good minute to get up to speed, making 4 ways and merging awkward. I'm wondering if someone else has had this problem or knows the solution. It has a rough idle when it's cold but that's Toyota. I'm tempted to take it in and see if a mechanic knows off the bat what's wrong but a common theme on here is dumping tons of cash on a goose chase. Thinking it's either a timing issue or vacuum leak. Help would be much appreciated. |
I think your on the right track... |
Solved
PROBLEM SOLVED
Wasn't a vacuum leak my clutch was blown. Recently hauled a heavy-ish trailer. Just didn't happen gradually. It was probably the original one. |
Didn't you see that in the tach? (The rpms were rising, but the mph was not.)
Originally Posted by scope103
(Post 52423258)
