88 runner Power Steering Woes
Need a bit of help from the yotatech group.
Found some leakage at the PRESSURE SIDE POWER STEERING LINE. @ the connection to the Gearbox. I cant drive my runner as is so.. I Have been looking for this line for 3 days online NOWHERE has this even listed for my rig 1988 4runner 22re 5speed 4x4 Toyota Part# 44411-35140 BECOMES 44411-35081 ONLINE OE PARTS RETAILER = NLA. I would prefer to buy online if possible ANY HELP WOULD BE GREAT!!! OR Can I make it if need be? Any info on thread pitchs of pump+box? Again Im asking yotatech for HELP. Thanks everyone for making this a GREAT BOARD. Jeff |
Hey there. The 35140 # worked a little better for me. Shows a year range from '86-'90. The other # came up too but for '84-'85.
44411-35140 https://www.1sttoyotaparts.com/partscat.html as I suspected, the page with the part doesn't come up with the link. You will have to copy and paste the part # into the search box. If that price is too much of a poke in the eye for you, I just recently replaced mine with this. Quality is very good but the nut size is 16mm instead of the OEM 17mm. Kind of a PITA since I don't currently have a 16mm line wrench.(not a problem now but probably when I go to get that sucker off in 15 years...) http://www.rockauto.com/catalog/x,ca...,parttype,7320 This link defaults to an '86 listing because thats what truck I have listed with them but you can change that if you like. I'm pretty certain it's the same part. Good luck, what a messy job PS is. |
Originally Posted by yota4runna
(Post 51273936)
No problem. Grab your 5/8" line wrench. 16mm = 5/8" within a gnat's eyebrow.
Originally Posted by BLKNBLU
(Post 51273833)
BLKNBLU Thanks. I did see that ROCKAUTO has 3 parts listed. seams that theres 3 different manufactures. the first EDELMANN brand I have had issues with on other cars the second GATES is a name brand manufacture the third AC Delco is a 5 day wait. WHAT BRAND did you have good luck with? I was thinking the GATES. Please let me know IF you did have good luck with one of the others. Thanks again Jeff |
I've got the Gates. :great:
(Post 51274511)
Just placed my order Ill post up once its installed thanks again Jeff |
