88 Automatic Shift Problems
My father in law has an 88 4runner 3.0 with the automatic transmission. Bout a year ago the Over Drive apparently quit working. The light will not come on on the dash and it does not seam to engage either. Now more recently it is shifting all funky. It seams to skip second gear and go right into 3 dog down and stay there. If you floor it hard it will drop into first for a sec and then blast right back to 3rd. If I shift it manually it seams to work OK. I am guessing the valves maybe? I don't know diddly about automatics. He wants to sell it and its a hard sell with this problem. Anyone have a best guess as to a probable cause and rough cost for repairs?
I had this problem while i had my auto, first things first, change the filter, then add some lucas auto transmission additive. Now if that doesnt fix it, i cant remember for the life of me what your issue is called but, you'll need a new tranny. Now for the overdrive, see if it's plugged in first, clean the connectors etc. If the light still doesn't come on, its a computer issue, that could also be your shifting issue. I switched out my computer for a junkyard one and it solved all my issues. If he wasnt selling it, id say just swap a 5 speed, i did and its awesome. If you want to switch out your transmission computer, and cant find one in your area you can pm me, i have one left over from my swap.
Originally Posted by motocrossaddict223
(Post 51987274)
Sent you a PM.
Start by adjusting your TPS, that cured the shifting problems i had with mine. www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
yea i agree, i would do everything thats free first, why spend money you don't have to
You need to unplug the ECT and do a manual shift. The ECT for the tranny is under the console under the radio. If you're skipping a gear, that's a sign of a bad shift solenoid. With the ECT unplugged, L is 1st, 2 is 3rd, and D is OD. You will not have 2nd gear because the solenoids are disabled. The OD light will blink a code.
Ground square plug http://i22.photobucket.com/albums/b3...4RUNNER005.jpg switch ignition on http://i22.photobucket.com/albums/b3...4RUNNER447.jpg http://i22.photobucket.com/albums/b3...wless/340F.jpg http://i22.photobucket.com/albums/b3...MISSION109.jpg http://i22.photobucket.com/albums/b3...OLENOIDSID.jpg http://i22.photobucket.com/albums/b3...lenoidtest.jpg http://i22.photobucket.com/albums/b3...SOLENOIDID.jpg Shift solenoids work in a pair, off and on 1st gear- solenoid 1 on, 2 off 2nd gear- no. 1 on, no. 2 on 3rd gear- no.1 off, no. 2 on OD- no. 1 off, no. 2 off |
