87 turbo Wheeling for the first time, issues.
just got my 4runner back from the shop amd after making just a few passes in the mud the manifold was glowing red and this thing is GUTLESS, like dangerous to pull out in traffic gutless, a buddy i was with said that the timing was off and i havent had a chance to check yet but is there anything else it could be? The coolant temps are fine throughout. Also when im driving with my headlights on and i use my turn signal or turn on the heat, the digital dash will freak out and go blank. Is that an alternator issue or what?
Check your cat, and see if its clogged, that might be causing the redness and gutless.
What was done at the shop? Did it run OK before it went in?
Timing could cause that issue. So could a cracked exhaust manifold/turbine housing. |
Originally Posted by Turbo4Runner
(Post 50669795)
also im looking for the turn signal flasher becuase mine are blinking super fast and i cant find it under the dash.....
Well then I sure hope it's not the turbo or manifold... :)
Get a timing light and check your base timing (don't forget to jumper the diagnostic pins. I forget which ones they are, searching will tell.) Also check your intake for boost leaks (a leak between your turbo and head). You can do this by making an adapter to clamp over your turbo's inlet with PVC and a tire valve. Pressurize it with an air compressor and see if air is leaking out anywhere. A good sized leak would result in a lack of power and the turbo being worked very hard. Turbo over worked = super hot and glowing. Also, its not totally uncommon for some glowing under the hood if you have been running it real hard. Just be sure to let the truck idle for a while and cool down before you shut it down or you'll destroy the turbo in pretty short order. Good luck! |
(Post 50669855)
Get a timing light and check your base timing (don't forget to jumper the diagnostic pins. I forget which ones they are, searching will tell.) Also check your intake for boost leaks (a leak between your turbo and head). You can do this by making an adapter to clamp over your turbo's inlet with PVC and a tire valve. Pressurize it with an air compressor and see if air is leaking out anywhere. A good sized leak would result in a lack of power and the turbo being worked very hard. Turbo over worked = super hot and glowing. Also, its not totally uncommon for some glowing under the hood if you have been running it real hard. Just be sure to let the truck idle for a while and cool down before you shut it down or you'll destroy the turbo in pretty short order. Good luck! Any thoughts on the dash? thanks for the link to the website too! very helpful people on here thanks........ |
Was it running OK before mudding?
A red manifold indicates either very retarded timing and/or a lean mixture. Both can cause performance issues. The bad news is that to get the manifold hot enough to get it to glow, you're hot enough to immediately coke oil - which can damage the turbo. I've baked two turbos this way.. :-) Base timing is easy enough to check. The timing should advance with RPM. I'd spin the turbo compressor by hand to check it. |
Originally Posted by dcg9381
(Post 50669955)
Have you already checked all your fuses for the light problem?
Originally Posted by 87turbo
(Post 50669967)
nope, had no power before i went, i was only in the mud for like 5MIN tops but the drive there was about 15, truck has to work WAY to hard to get going. i hope i didnt just ruin a $1500 turbo kit.......
If it was for the turbo kit - it sounds like they didn't check the install work. |
in the shop becuase the motor was seized so it was totally gone through....
back from muffler shop cat and muffler checked out perfect. |
I had a 87 Turbo 4Runner and it was totally gutless when you first take off but as soon as the turbo spooled up it pulled real hard, even out ran a Chevy V-6 S-10 one time. My dash lights also went crazy sometimes. Can't remember but had something to do with turning the lights on or turn signals. Never did fix it or find the problem but it did it for a couple years that I had it and I think I always suspected a faulty ground to the instrument cluster. I don't think it is battery or alt. related and never caused a problem other than not being able to see the instruments. Can you hear the turbo spooling up?
Originally Posted by Supra 4x4
(Post 50670168)
AWESOME! messed with the timing and this thing is a whole nother animal, have it at about 12* right now and it runs awesome.
(Post 50669819)
that is usually a warning that one of your blinker lights (outside) died. turn on your hazards and walk around your truck to see which one is out. glad to hear the turbo is working:D |
(Post 50670277)
Originally Posted by idanity
(Post 50670447)
(Post 50670629)
What was it at before? I'd have a field day with the shop that did that work.. If they went through the motor, put on a new turbo, and didn't bother to test the truck or check the timing - that indicates some not so good workmanship.
it's a buddy with a shop and i get half price/ get what u pay for |
