87 climate control light
I have a 87 4wd SR5 pickup and my climate control light is out. I called the dealer and they have no clue where I can get one and I don't want an LED light. Does anyone know where I can get a light (S14V) Also, my temp and oil pressure light barley light up. Anyone know where I can get stock instrument cluster lights?
-Thanks! |
You can get these light bulbs at any auto parts house. The climate control light bulb is a mini bulb. Pry the faceplate off carefully and take the old bulb with you to match it up. The dashboard bulbs are just larger versions of the climate control light. You will have to take the gauge cluster out to access them. I recommend Sylvania 168 bulbs for the gauge lights as these bulbs give off more light. If they are to bright at full power you can always dim them a bit. Most L E D bulbs won't dim. (just saying)
