86-95 Pickup and 4Runner Headlight Conversions
Are you tired of driving down the road with the DIM factory headlights.
you know the ones that im talking about. The old style Halogens, that emit a yellow, darkish color light. If you are, you are in luck with the HEADLIGHT CONVERSION. With this set up, you will go from the sealed glass lights to a nice set up. It will have the replacement Headlight housing that is a durable plastic. The bulb is switched to a H4 style bulb that is replaceable. There is 2 different style bulbs that you can go with. You can go with the regular H4 Halogen style bulb, this is going to be a little bright than what you have now. Or you can upgrade that to the Vision X H4 bulb, this bulb is a step down from a HID.. With this your night driving problems are solved. Less strain on your eyes as you are driving down some old 2 lane highway in the middle of nowhere. Or if you are like the guys here at LC, Some old dirt road or up in the mountains.. Check this out and let me know what you gentleman think.. Here are the links for you guys. The 1st is the Regular H4 bulb The 2nd is with the Vision X H4 bulb http://www.lceperformance.com/H4-Hea...-p/3061016.htm http://www.lceperformance.com/H4-Vis...-p/3061020.htm |
I have the new style grill on my 2nd gen 4runner? So these arent direct replacement are they?
With the Grill what year is it off of? More of what headlights are you using now?
If you are using the factory headlights, these will fit. Andrew |
These are factory headlights on the 95 4runner. These are different from the 1990 4Runner.
Here is an example. 90 http://i597.photobucket.com/albums/t...g?t=1257385876 95 http://images.esellerpro.com/2133/I/...headlights.JPG |
