'86-'92 Toyota Supra AFM
Old 09-30-2008, 01:46 PM
rusche's Avatar
Is this the year you can use on a 22RE?
I've heard a rumor that its a popular mod for more airflow, and I figured Id ask since I just spotted this on craigslist
http://spokane.craigslist.org/pts/860546631.html
Old 09-30-2008, 04:47 PM
myyota's Avatar
The one i have for my 86 4Runner with a 22RE is from a 5M-GE engine, im not sure if the one your looking at will work on your truck though.
Old 10-01-2008, 05:38 AM
Junkers88's Avatar
I know this is going to sound stupid but does the valve cover or something say 5M-GE? If no then how do you know what engine is in the Supra?
Old 10-02-2008, 09:18 PM
874runnersr5's Avatar
would one work from a 86 7m-ge?
Old 10-03-2008, 01:02 PM
SR5
SR5's Avatar
ok so
86.5 to 92 is a 7m-ge or the 7m-gte ( T for turbo )
and the 5m is from the supra celica model before it
i dont know wich fit your model as i have a 3vze but if you would like to brush up on your supra knoledge go here
http://www.supramania.com/
Old 10-04-2008, 06:42 AM
ah, thanks man
Old 02-13-2009, 12:10 PM
Dr.Irwin Goodlove's Avatar
Don't get stuck on just finding a supra, the cressida's were the flag ship models and they all had the 5mge motors steal the box and the Maf out of them. The throats are way big as well
Old 03-06-2009, 12:30 AM
ffryno13's Avatar
the supra 82 will direct plug and play to 22re only the 82 which is the 5mge
Old 03-06-2009, 07:03 PM
myyota's Avatar
Thats what my AFM came from, now i just need to get it installed.
Old 03-06-2009, 07:16 PM
ffryno13's Avatar
oh man its easy it took me like 10 min for real. and its way better and cheaper then the LCE intake kit. i have the LCE version on my 2wd
Old 03-06-2009, 10:47 PM
annoyingrob's Avatar
A 7M-GE versionI believe works with an electronics swap, much like the later 5M-GE ones. I think it's the same size as teh 5M ones though.
A 7M-GTE one will NOT work. It's a completely different style of AFM.
Old 07-25-2009, 06:48 PM
ozziesironmanoffroad's Avatar
i know, im ressurecting an old thread. but myyota, did you ever get it installed? and if so, how did you mount it up? i know its plug and play, i had one but sold it to a member on here, and will soon be buying it back. my problem with it was i couldnt get it mounted properly, due to not having the bottom piece for it. how did you correct that?
Old 07-25-2009, 06:58 PM
Junkers88's Avatar
I mounted mine on both rigs using some all-thread and bolts as uprights. Mounted them in place of the battery once the swap was made with the battery and factory air box. It's a little ugly but it works.
Old 07-25-2009, 07:54 PM
myyota's Avatar
Originally Posted by ozziesironmanoffroad
i know, im ressurecting an old thread. but myyota, did you ever get it installed? and if so, how did you mount it up? i know its A and play, i had one but sold it to a member on here, and will soon be buying it back. my problem with it was i couldnt get it mounted properly, due to not having the bottom piece for it. how did you correct that?
No, i havn`t had a chance to install it yet, Im moving in a few months and i just have not had the time to deal with it yet. It shouldn`t be to hard to mount, just get some metal stock from the hardware store and make some brackets to mount it, thats how im going to do it when i install it.
Old 07-26-2009, 07:14 AM
BigBluePile's Avatar
Yup, I just used some metal left over from my K&N kit and I tap a hole in the back(not inside the afm but thru one of the tabs) of the AFM and Viola! Easy peasy.
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
crashburnoveride
08-28-2015 09:20 PM
nick b
07-11-2015 04:38 AM
Quick Reply: '86-'92 Toyota Supra AFM
