4cyl vs V6 3rd members...differences?
I pose a queston as I'm in the market for a new third member for my V6 '91 truck. I keep seeing posts and ads for various 3rd's with various gears and lockers. My biggest confusion comes in the question of:
"What is the difference between a 4cyl and a V6 3rd?" What is the advantages and disadvantages of each? Will a 4cyl 3rd work on my V6 truck? If so would I want to do this? Any and all help is appreciated. Even if you don't want to answer but rather post links to sites where I could read for myself, any info would be appreciated. Thanks -=Morphine=- |
Hey Morphine,
I asked the same questions about a month ago, which was before I swapped in my 4.56 V6 3rd in place of a 4.10 4cyl 3rd. It was a straight bolt in swap. Here are some links that may help you: http://home.4x4wire.com/erik/diffs/ http://www.toysport.com/Technical%20...ifications.htm http://toyota.off-road.com/toyota/ar....jsp?id=274535 Troy |
Originally Posted by Morphine
(Post 50512622)
Will a 4cyl 3rd work on my V6 truck? If so would I want to do this? Troy |
The V6 version has 4 spiders and has extra ribs cast into the housing. This is no big deal if you intend to replace the carrier with a locker.
Troy,
Thanks for the info. One question however is the difference between the 2-pinion and 4-pinion? What does this translate to in english? Also would there be a considerable price difference betwen them, since the V6 is more desireable, it seems that it should command a higher price. Now to continue on - If my truck see's light wheeling, maybe 4 to 6 times a year, and easy to mild trails, would it be a "bad" decision to go with the 4cyl 3rd? Looking for opinions here, I know no one can give me a correct answer just opinions. Thanks -=Morphine=- |
If you don't wheel hard, don't sweat trying to get a V6 third. The 4cyl one is fine.
(Post 50512636)
Troy,
If my truck see's light wheeling, maybe 4 to 6 times a year, and easy to mild trails, would it be a "bad" decision to go with the 4cyl 3rd? Just my $0.02 |
Originally Posted by RustBucket
(Post 50512639)
Troy |
(Post 50512636)
Troy,
Thanks for the info. One question however is the difference between the 2-pinion and 4-pinion? What does this translate to in english? Also would there be a considerable price difference betwen them, since the V6 is more desireable, it seems that it should command a higher price. Thanks -=Morphine=- I don't know. All I know is that the carrier, and pinion gear for the V6 3rd is stronger than the 4cyl one. Having said that, I've heard that if you plan to lock it, it won't matter, because you'll be replacing said components anyway (other than the carrier). Troy |
Originally Posted by troy65
(Post 50512649)
I guess we're lucky out here in Vancouver, BC. V6 3rds seem to be a dime a dozen. I picked up my V6 4.56 3rd for $150 and the front IFS for $80.
Troy -=Morphine=- |
