4-Runner Rear Window INOP!
Hey Gang,
The rear window on my 1995 SR5 4Runner just stopped working....both the rear door key switch and the front console rocker switch are 'dead'....no movement in the window..... Is there a fuse for this system, if so, where the heck is it??? I pulled the interior panel, and it is no help, all the connections are fine, and I don't have anyone to hit the switch with me in there to check for voltage. Ideas??? THX Greatwhite Phoenix, AZ |
The fuse is easy to check. On the 94, it's located right in front of the driver side door. There is a cluster of fuses numbered like this:
1 2 3 4 5 6 7 8 9 Number 4 should be for the window. |
