3vze idle drop when remove oil cap??
Just like the title says, I have recently rebuilt 3vze, just replaced the cam plug cause it was leaking. So I started it up after the fix, and I don't know why but I removed the oil cap and the the idle dropped pretty significantly. I put my hand over the oil fill hole and it niether sucked my hand nor pushed air out. Is the idle drop normal? My buddy was pretty surprised, he's never heard of that happening in the fords he works on.
Thanks |
Yes, normal to have idle drop.
Originally Posted by rworegon
(Post 52072280)
...or just funky idle either way with the cap off.
I'm thinking cause it's fooling the air in take?
Yeah, it basically creates a vacuum leak. There was another thread recently on this exact issue and someone had a good explanation, IIRC. :)
I resurrect thee...
https://www.yotatech.com/forums/f5/2...-wierd-141477/ |
Originally Posted by MudHippy
(Post 52072469)
I resurrect thee...
Happens on any non-carbureted engine with a PCV system.
(Post 52072563)
